Hi All
I'm having a few problems with the speedo
I have finally got it working went out with the sat nav to get the correct speed.
the speedo is not that far out but It gives a very irratic reading suddeny jumping up 10 to 20mph then back down.
Is this down to the fact I'm using 8 magnets would I be better to go down to 4 and then adjust on the speedo healer
Im using the triumph clocks and sensor
any ideas anyone
Lee
ps This th last job before SVA re test
Most people use 4 or even 2 magnets, also check the gap and the stability of the bracket holding the sensor.
Another thing, use shielded twin core and earth the shield one end.
