Still not bloody working!
leemarkadams - 11/8/09 at 06:09 AM
Hello all, well have got a replacement relay as in the post here:
http://www.locostbuilders.co.uk/viewthread.php?tid=118624
Connected it all up, with a working fuel pump too, and nothing. When you turn the ignition key to position 2 the fuel pump does not even prime like it used to!
So, any ideas as to what to try next, as have done all the tests in the workshop manual and they all passed ok (except the relay).
The only things I can think of are the side stand switch (but am getting a negative signal on the light blue wire at the relay), as the neutral switch is working. So what else can I sodding well do (before I think of ripping the whole car apart :mad............If it is the side stand switch how do I ensure it is bypassed correctly?
As I said before it was working really well on the track day before it just coughed and spluttered then died. Initial tests showed the fule pump was not working at that time, further tests have shown the relay was gone too.
Anyway, any help greatly appreciated as I do not want to call in a professional if I can help it!
Lee
[Edited on 11/8/09 by leemarkadams]
rgrs - 11/8/09 at 06:30 AM
Do you have a test meter ?
Roger
leemarkadams - 11/8/09 at 06:31 AM
Roger
Hello, yes I do have a test meter, in fact just been out in the garage now and am not getting a signal at all on the blue/yellow wire to the relay (coming from the side stand) so wonder if that is an issue?
rgrs - 11/8/09 at 06:38 AM
Does your loom contain the cycle lock option ?
and whats the voltage on the 1st wire red/black left connector with the ignition on
Roger
[Edited on 11/8/09 by rgrs]
leemarkadams - 11/8/09 at 06:52 AM
Roger
Just tested the wire and it is getting 13.46 volts. Am also getting power to the coils red/black also.
As for cyclelock, no idea, as the car was buult when I bought it and was running fine until the track day.
rgrs - 11/8/09 at 07:04 AM
check if you have a neg on the black/yellow 4th from left.
also have you tried the fuel pump off the car
leemarkadams - 11/8/09 at 07:16 AM
I have a negative on the black/yellow you mention and the fueln pump works fine if you run wires direct to it.
Bloody car!
mad-butcher - 11/8/09 at 07:19 AM
Lee
Take the fuel pump fuse out and make shaw you have 12v on the terminals, then try putting a new fuse in, (or at least one you know works )
tony
[Edited on 11/8/09 by mad-butcher]
Flamez - 11/8/09 at 07:20 AM
Although my car is a kawasaki I wired the two wires in the connector of the side stand directly together and it works fine
adithorp - 11/8/09 at 07:23 AM
It's unlikely to be the clutch, side-stand or neutral switches as they all stop the starter operating. From what I remember of your earlier posts it does turn over?
Does your car have the Cyclelock? Most BEC are built with looms that don't have it.
adrian
[Edited on 11/8/09 by adithorp]
leemarkadams - 11/8/09 at 07:27 AM
Thanks for the help so far, but still no joy!
Not getting the fuel pump priming via the relay, or the engine sparking! It will turn over but will not fire and no spark seen with a plug out and grounded......
Lee
rgrs - 11/8/09 at 07:37 AM
Try wiring the fuel pump direct to a 12v supply, the pump should then run until pressure is reached and then shut down. Once its done this try starting the engine, at least this will show if its a supply problem to the pump only. Check to see if there is a spark.
Must type faster
Roger
rgrs - 11/8/09 at 07:55 AM
Seems it could be related to your ecu, disconect the ecu and check for corrosion. whilst its still disconected with the ignition on apply a neg to the blue/red on the ecu connector. The fuel pump should run. If it does then the fault is either the ecu or if fitted the cycle lock system. This is an anti theft device and a bit of a pain.
Where abouts are you ?
Roger
mad-butcher - 11/8/09 at 08:04 AM
Sorry just been out to check and I should have said ignition fuse
tony
adithorp - 11/8/09 at 08:06 AM
Without knowing if the Cyclelock is fitted or not it's not really posible to diagnose the problem.
If it is fitted it could well be that. If not fitted then you're working from the wrong wiring diagram.
adrian
mad4x4 - 11/8/09 at 11:51 AM
Ok not knowing much about bike electrics I would throw this in to the equation
If the Fuel Pump is not running and there is no spark then that would be typical 2 point imobilisation of a thatcham Alarm system (cyclock??).
So what you will need to do is trace the wire back from the fuel pump back to find the imobilser (which will be seperate from the ECU well possibly) and try and figure out why it is energised.
Usually a car will have 4 Door switches and and a movement detector (inside) with possibly a tremble switch as well as crank switch etc.
On a Bike not so sure. there must be a tremble switch to stop someone wheeling the bike away. as well as a side stand switch and a crank switch - One mate had a pressure switch under the seat so the bike would only start if he was sitting on it.
It could be that the track day has caused the tremble switch or one of the other switches to fail so the bike thinks the alarm is constantly enabled.
Do you know what bike the LOOM came from you may be able to get the OEM diagram,
leemarkadams - 11/8/09 at 03:17 PM
Roger
Tried this and not a sausage!! Whether a positive or a negative is applied to the wire you mention.........
Really starting to get despondant now and the wife is not too impressed as she did not want me to get the car!! Still, could always be worse I suppose!
Any more ideas before I rip out all the wiring and start again, as do not really want to do this as it was working fine before!
Lee
leemarkadams - 11/8/09 at 03:20 PM
adrian
How do I tell if it has cyclelock fitted? It was working fine before.....
adithorp - 11/8/09 at 05:01 PM
adrian
Either...
Ask the guy who built it. While your at it ask if there's an inertia switch somewhere (that'd cause your problem) or a security switch hidden away that might have been knocked off.
Or...
Check the wiring against the diagram in your last thread and see if you can trace wires going to the cyclelock.
I'm more familiar with the injection engines but I think...
Without the lock you'll have main ignition wires red switched to brown/blue and secondary ignition of blue/yellow to blue/black. The secondary might be perminently connected in the loom, but if disconnected/broken would cause your problem. If the ignition feeds to something else then you've probably got a Cyclelock.
Tracing back the existing loom has to be simpler than making a new one.
leemarkadams - 12/8/09 at 10:37 AM
Just had a motorbike mobile mechanic round (friend of a friend hence lo-cost!) and he reckons it could be the ICU if everything else has been checked, so I guess that is the next thing!
Ah well, a call to Yorkshire engines it is....
Lee
mad-butcher - 12/8/09 at 01:45 PM
were abouts are you maybe someone handy could loan you theirs to try
tony
leemarkadams - 12/8/09 at 03:28 PM
I am near Portsmouth.........
Lee
leemarkadams - 13/8/09 at 07:16 AM
Well, bit the bullet and ordered an ICU from Malc at Yorkshire Engines, so will give it a try when that arrives.
If that does not work then I guess it will be strip all the old wiring out and start again, as was planning on doing that over winter anyway as well as put in FIA cut off, savage switches etc...
Lee
RickRick - 13/8/09 at 08:03 AM
do you have a lean angle switch on a 99 r1? if so having this facing the wrong way, atleast on my 05 presents the same problem, turning over, no fuel pump or power to injectors
leemarkadams - 13/8/09 at 08:41 AM
Have not seen one on mine, as did not build it but looked at everything else and not seen it at any stage. I am sure mine does not have 1...
I will get it working again!
Lee
Scott W - 13/8/09 at 10:24 AM
Out of interest, did you change the plugs as I never saw a response to that?
hobzy - 13/8/09 at 11:21 AM
Let us know how it goes Lee. If your bored, you can come and try and get my lights rear working! All working fine until I put the switches into the new damn dash
ETA scratch that fixed it
[Edited on 13/8/09 by hobzy]
leemarkadams - 13/8/09 at 12:36 PM
Show off!
I did change the plugs also and still no spark or fuel pump working through the loom...
mad-butcher - 13/8/09 at 08:01 PM
hope the new part works,
tony
leemarkadams - 13/8/09 at 08:14 PM
tony
Not as much as I do!!!!LOL
leemarkadams - 14/8/09 at 11:34 AM
Well, got the replacement ECU and................no change! (no fuel pump or spark, the starter turns but that is on a seperate button).
What the hell to do next, as starting to get a little bit annoyed now!
Have tried looking for a tilt switch and not seen one, besides don't believe a 99/00 R1 has one if I am correct.
CYCLELOCK could be a cuplrit if a wire has come loose somehow, but how do I go about re-wiring it, and how do I tell if mine has a CYCLELOCK fitted, as there are a few black wires giving +ve and -ve loose within the loom. But they do not look as though they have ever been connected.
'Help me Obi Wan.............you're my only hope!'
