Hi all can someone please tell me which wires are, main, dip, and sidelight, the lights are made by autopal
Rescued attachment autopal headlight wiring
is there no way you can just connect the wires to a battery?
thats how i did mine
well the side light is the little bulb at the bottom. red cable
The other wire on the side light is an earth wire ( and it loops up to the head/main beam bulb) Black cable
the blue/white is the main beam
the blue/red is the dip beam
from the bulb side
[Edited on 23/8/09 by omega 24 v6]
Ok thanks
