Laws on LED lights
j30fos - 25/3/04 at 04:02 PM
I'm looking at changing my rear lights ( all ready :-)) for some LED ones. The lights are American and are all red LED's http://www.led-r-us.com/lights.shtml the lights are the 5506r, Is it illegal to use these lights ie. Flashing red rear light as the indicator. I cannot see a problem as some of the limos I see have flashing rear red lights.
Does anyone know.
Or is anyone interested in a group buy If I can organise one.
John
ned - 25/3/04 at 04:08 PM
i'd be very converned about flashing red lights for indicators. wouldn't they fail mot? if you've already passed sva that is. i'm very sure they'd fail an sva.
imports may get them in under a different set of rules or something..
Ned.
timf - 25/3/04 at 04:10 PM
imports have to change to a set of amber ones.
look at construction and use regs says amber.
any limos running red ones are illegal
j30fos - 25/3/04 at 04:11 PM
Ned, Im sure your stalking my posts. minutes to reply this time :-)
Thats what I need to find out if it would fail an MOT.
Steve @ sVc - 25/3/04 at 04:17 PM
John
Your Mot tester "should" fail you with red indicators if the car was registered after 1st Spetmeber 1965 - I'm sure it was!
Regards
Steve @ sVc
wicket - 25/3/04 at 04:18 PM
Check this link, it says amber.
http://www.ukmot.com/manual/1-5.htm
j30fos - 25/3/04 at 04:24 PM
The boys, I knew the answer would be on here. So the only way around this is to buy the red one and an amber one :-(
I can't find any with both red/amber for the right money.
Cheers lads for the reply's
John
GO - 25/3/04 at 04:51 PM
I asked this question a while back and got same answer unfortunately.
Thought twin round red lights would look pretty sweet.
bummer really.
ned - 25/3/04 at 05:01 PM
could use a round red reflector i guess to get the affect, these are available. then use a clear lense indicator with an orange bulb?
Ned.
Steve @ sVc - 25/3/04 at 05:25 PM
We have 95mm diameter LuxVision LED red- stop/tail lights and same size amber LEDs - all "E" marked ansd squeeky clean SVA wise, good value (for LEDs) - on the web site.
Also, but not shown - a Hella 95 mm clear lens stop/tail (red AND amber indicator in the same light.
Bit on the pricey side tho' @ £112 pair inc. vat (sorry).
Regards
Steve @ sVc
