I have done a search but cannot find one but don't mind being proved wrong.......
Is there a list of the maximum legal wattage for car lights.
Side
tail
dip
Main
Stop
Indicator
Repeater
rear Fog
front fog
Reverse
and any I've forgotten
RD
5
5
55
65
21
21 (front and back)
5 (repeater)
21
NA
NA
Main and dip are questionable as some aftermarkets are 120w plus though maybe not legal.
Front fogs dont have a limit. But are usually 55/65
Reversing are usually 21W (same as Fog) but can be whatever you like AFAIK
Cheers David
More than 21w white light to the rear is illegal.
ie No Spot lights as reversing lights.
I nearly got done for that many years ago!
You might get away with it on a pickup or a van as a "loading light", but you wuold be on dodgy ground.
I did forget one ....... Number plate lamp
Ill assume 5w is OK
RD
Ill assume 5w is OK
RD![]()
Front Dip 55w
Front Main 65w
Other bulbs are available but are not road legal and are sold as off road/show use only.
