Megasquirt Code Hair Loss....
MakeEverything - 23/9/09 at 11:24 AM
Im trying to upload the code for my V2.2 Megasquirt, but am struggling to get it to connect.
When i short the boot jumpers, and go through either hyperterminal or code uploader, i get the following messages;
MegaSquirt Download 2.00
Reading C:/Program Files/MegaSquirt/Monitor_v2.890.abs.s19:
Detected MS-II (HCS12) code.
Entry point: 0x0000
Code range : 0x4000-0x3db420
File read successfully.
Opened comm port 1 at 115200.
ERROR: Unknown error status response, e=0x00
Elapsed time: 0.34 seconds
Entry point: 0x0000
Elapsed time: 0.44 seconds
What am i doing wrong? I got the MS second hand, so i dont know its condition at the moment.....
Mr Whippy - 23/9/09 at 11:29 AM
seems to be looking for connected ports and not finding any
brianthemagical - 23/9/09 at 11:31 AM
Have you tried with the boot jumper disconected?
Can't remember of the top of my head how it works/the correct order, but do you need to turn it with the boot jumper disconnected and then follow the instructios?
Are you usinf the corect code for the MS version?
Can you access it through tuner studio?
MakeEverything - 23/9/09 at 11:36 AM
Ive managed to get it to load the MS1 V3 code (looks like i was trying the MS2 code!) but i still cant connect to it using Megatune.
The computer sees the port, and the code just loaded (with lights flashing etc) but i still cant connect to megatune??
Ive got the stim, which im using to power the unit, and to test....
Any ideas?
brianthemagical - 23/9/09 at 11:40 AM
Have you set the connection settings in Megatune?
Have you got portchecker, or something similar. It's a life saver when trying to connect MS.
MakeEverything - 23/9/09 at 12:15 PM
Its definitely working on the port. COM1 says "Bowling & Grippo V2.xxx or V3.0" at 9600bps.
Im sure the issue is with the files on the megatune software. Is this a possibility?
MakeEverything - 23/9/09 at 12:17 PM
when i start megatune, it comes up with;
"Controller version code does not match the signature in megasquirt-II.ini" then goes on to ask if i want to terminate megatune...
BenTyreman - 23/9/09 at 12:23 PM
Go into the configurator and select the correct code branch (you currently are trying to use the MS2 INI file for MS1 code).
Personally I would ditch MegaTune for TunerStudio (http://www.efianalytics.com/TunerStudio/). TunerStudio should be smart enough to use the correct INI file, or download it if you don't have it on the computer.
[Edited on 23/9/09 by BenTyreman]
MakeEverything - 23/9/09 at 12:34 PM
How do i do that?
Im downloading as we speak!!
[Edited on 23/9/09 by MakeEverything]
MakeEverything - 23/9/09 at 12:58 PM
Wow, Tunerstudio is MUCH better!
And it works now too!
Thanks Ben, youre a Legend.
matt_gsxr - 23/9/09 at 04:35 PM
TunerStudio is good agreed.
The only problem when using both is that the .msq files throw some warnings in TunerStudio (Tae and Mae rates units) which when corrected in TunerStudio won't work in MegaTune (MegaTune wants the wrong units of "ms".
I agreed on the benefits of TunerStudio, but when things are not working its always nice to go back to software that you KNOW worked (rather than a potentially dodgy beta).
Matt
MakeEverything - 23/9/09 at 09:23 PM
Ive just discovered that there is no rev limit function either, but hey, its got me started.
BenTyreman - 23/9/09 at 09:49 PM
Have you considered moving to the MS1 Extra or Hi-Res code branches? They do have rev limits along with other goodies.
MakeEverything - 24/9/09 at 08:22 PM
No, but if it involves changing hardware, ive only just got this one!!
