Hi all
I need a double pole three position switch that has off- on - on like the Lights off/side/head switch from places like Vehicle Wiring, but double
pole.
Any ideas where I may get one?
Regards
Wyn
maybe just use normal single pole switch wired to two double pole relays?
try these
Auto Electric Supplies
or
Premier Wiring
tony
[Edited on 23/9/09 by mad-butcher]
Found one -
RS
I'm planning on using it as a combined master switch position 2 (controlling something like a Cartek isolator) and ignition relay at position
3.
W
I spent ages looking for one and finally found Durite do one. I'll look up the part number tommorow.
adrian
Strange - that link I posted was supposed to be the RS site! Adrian - did you manage to find the part number?
Ta
Wyn
[Edited on 5/4/10 by lsdweb]
No, but I'll try and remember tommorow.
adrian
The switch I used for side/head lights was Durite 0-645-00
Listed as off/a/a+b three position side and headlight single pole light switch.
adrian
