Megajolt Loom Wire
nathanharris1987 - 29/9/09 at 06:22 PM
Ey up,
Just reading up about EDIS and megajolt wiring, on the autosportlabs vehicle installation guide it says to use 12-14 gauge wire. What does this mean in english?
CLICK
Its about halfway down this page.
ta
big_wasa - 29/9/09 at 06:35 PM
Standard wire gauge
Link
If you need any wire / plugs / help give me a shout mate.
nathanharris1987 - 29/9/09 at 06:41 PM
ta muchly! quick to pounce there mate!
were you doing a delivery to market deeping monday? i was just coming out of frognal area when a tanker zipped by.
snapper - 29/9/09 at 06:55 PM
Make sure you use the sheilded wire in the right place and properly earthed.
Trigger Wheel .com do the stuff and you can find it in Maplins.
I had a lot of problems with the plug on the VR sensor so make sure it is properly connected and secure it against vibration and cable pull.
big_wasa - 29/9/09 at 06:56 PM
Yeh could be by zip by you mean 40mph
nathanharris1987 - 29/9/09 at 07:06 PM
cheers snapper
yeh wasa tanker going slow but i was making fair progress in a works truck!
So you reckon somthing like ref 25 on this page?
link
dhutch - 29/9/09 at 07:12 PM
I used leads removed from the 'donor' for the crank position and tps. For plug into the edis i used wire that came with it. For the wire to the MJLT itself i used the wire of a computer power supply which i got the plug off. Swapping the wires around so the thick ones become the current carrying ones and the colours made sense. Then used some cut up loom from a 306 for odd other bits.
Total cost = very low! Time taken = not much.
Daniel
