starter motor direction
Lightning - 4/10/09 at 05:11 PM
Which direction does a honda or rover starter motor turn - viewed fron the opposite end to the gear.
My reverse gear attempt goes forward...bum
t16turbotone - 4/10/09 at 05:16 PM
is there any way to reverse polarity on starter motor?
theconrodkid - 4/10/09 at 05:17 PM
they do spin the wrong way,can you mount it the other war round,should go backwards then....or get another starter
Lightning - 4/10/09 at 05:25 PM
no room on the other side. The reason i want to know which way they rotate is to change the starter. I think I have a Honda civic and hope the rover
goes the opposite way
matt_claydon - 4/10/09 at 05:37 PM
IIRC Honda engines are known for going the 'wrong' way.
Andy B - 4/10/09 at 06:09 PM
You need Honda VFR400 nc30 starter motor - it spins the opposite way to the rest because of the bikes gear driven cams.
Do not attempt to reverse the polarity on the one you have - it will go bang, I know I tried it twice
hope that helps
regards
40inches - 4/10/09 at 08:13 PM
There is usually an arrow stamped on Bosch starters, I used a VAG starter, small, powerfull and runs the correct way
http://www.youtube.com/user/fourtyinches#play/all
Lightning - 4/10/09 at 08:50 PM
Thats great but I cant quite make out which direction it is turning. Could you tell me which way. Many thanks
40inches - 5/10/09 at 10:00 AM
Looking at starter from the gear end, anti clockwise. I looked at Ford starters, they run clockwise, well the ones I looked at did.
Lightning - 5/10/09 at 10:06 AM
Brilliant. Thats what i want. Any Idea the model etc.
Looking at Z cars they put the starter entering from the other side. This would mean major alterations to the chassis etc, so a couterclockwise
solution would be far easier.
I thought the Honda would do, as the engine rotated the other way, but alas the starter enters from the gearbox side and hence the rotates the same
way.
Looking into the Honda VFR400 route still as well
[Edited on 5/10/09 by Lightning]
scudderfish - 5/10/09 at 10:37 AM
If a starter motor was just a DC motor then it should run in reverse. I'm curious as to what extra gubbins they have which is polarity
sensitive.
40inches - 5/10/09 at 11:36 AM
This any good
9T 1.1KW GR M8 N
LRT00177
Cross Ref:
0001121006
0001121007
020911023F
020911023T
You can get them new on the Bay for around £100, they fit all these models, so are relatively easy to find;
AUDI A3 1.6 00-02
AUDI A3 1.6 98-00
AUDI A3 1.6 AT 98-01
AUDI A3 1.8 AT 98-03
AUDI A3 1.8 AT 98-01
AUDI A3 1.8 Turbo AT
AUDI A3 1.8 Turbo AT 00-03
AUDI A3 1.8 Turbo AT 98-00 9T
AUDI A3 1.8 Turbo AT 98- 9T
AUDI A3 1.8 Turbo AT 99-00 9T
AUDI A3 1.8 Turbo AT 98-03 9T
AUDI A3 1.8 Turbo Quattro AT 98-00
AUDI A3 1.9 TDI AT 00-03
SEAT Alhambra 1.8 Turbo AT 98-00
SEAT Alhambra 2.0 AC AT 98-00
SEAT Alhambra 2.0 AT 00-
SEAT Alhambra 2.0 AT 98-00
SEAT Cordoba 1.6 96-02
SEAT Cordoba 1.6 AC 96-02
SEAT Cordoba 1.8 96-02
SEAT Cordoba 1.8 AC 96-02
SEAT Cordoba 2.0i 95-96
SEAT Ibiza 1.6 99-02
SEAT Ibiza 1.6 00-02
SEAT Ibiza 1.6 99-00
SEAT Leon 1.4 99-00
SEAT Leon 1.4 16V 99-02
SEAT Leon 1.4 16V AC 99-02
SEAT Leon 1.4 AC 99-00
SEAT Leon 1.6 99-04
SEAT Leon 1.6 16V 00-02
SEAT Leon 1.6 16V AC 00-02
SEAT Leon 1.8 20V AT 99-03
SEAT Leon 1.8 Turbo 00-01
SEAT Leon 1.8 Turbo 00-04
SEAT Toledo 1.6 99-
SEAT Toledo 1.6 98-
SEAT Toledo 1.6 98-02
SEAT Toledo 1.6 16V 00-02
SEAT Toledo 1.6 16V AC 00-02
SEAT Toledo 1.8 20V AT 98-03
SKODA Octavia 1.6 98-02
SKODA Octavia 1.8 Turbo 98-04
SKODA Octavia 1.8 Turbo 4x4 AT 00-04
SKODA Octavia 1.8 Turbo AT 00-04
SKODA Octavia 2.0 AT 99-02
VW VOLKSWAGEN Bora 1.6 01-05
VW VOLKSWAGEN Bora 1.6 02-03
VW VOLKSWAGEN Bora 1.6 98-01
VW VOLKSWAGEN Bora 1.6 98-05
VW VOLKSWAGEN Bora 1.8 Turbo 00-05
VW VOLKSWAGEN Bora 2.0 AT 98-05
VW VOLKSWAGEN Golf III 2.0 95-97
VW VOLKSWAGEN Golf IV 1.4 00-01
VW VOLKSWAGEN Golf IV 1.4 97-
VW VOLKSWAGEN Golf IV 1.4 99-00
VW VOLKSWAGEN Golf IV 1.4 AC 00-01
VW VOLKSWAGEN Golf IV 1.4 AC 98-
VW VOLKSWAGEN Golf IV 1.4 AC 99-00
VW VOLKSWAGEN Golf IV 1.6 97-
VW VOLKSWAGEN Golf IV 1.8 AT 97-98
VW VOLKSWAGEN Golf IV 2.0 AT 98-05
VW VOLKSWAGEN New Beetle 1.6 99-00
VW VOLKSWAGEN New Beetle 1.6 AT 00-05
VW VOLKSWAGEN New Beetle 1.8 98-01
VW VOLKSWAGEN New Beetle 1.8 99-04
VW VOLKSWAGEN New Beetle 2.0 AT 98-05
VW VOLKSWAGEN New Beetle 2.0 AT 98-01
VW VOLKSWAGEN Polo 1.6 95-97
VW VOLKSWAGEN Polo 1.6 AC 95-99
VW VOLKSWAGEN Polo 1.6 AC 95-97
VW VOLKSWAGEN Sharan 1.8 Turbo AT 98-00
VW VOLKSWAGEN Sharan 2.0 AC AT 98-00
VW VOLKSWAGEN Sharan 2.0 AT 00-
VW VOLKSWAGEN Sharan 2.0 AT 98-00
Lightning - 5/10/09 at 12:01 PM
I hope you copied and pasted those.
Magic
Thanks a lot
Lightning - 5/10/09 at 12:24 PM
Just checked and yes it rotates counter clockwise and has the right number of teeth. (wish I had)
