i'm after some 23mm warning lights, like these
http://www.cbsonline.co.uk/23mm-dia-warning-light-bank-wl23bank-4876-p.asp
but i only want the oil pressure and battery light.
cbs only seem to sell the whole set.
any ideas where i can get them individually?
i'm about to email them and ask
Hi. It says on the description
"Soon to be available separately with all legends."
yeah, but how soon?
i want them now!
(admittedly i misread that bit, i thought it meant the set of 6 with the ali plate was avaiable soon, which made no sense to me so i ignored it
Christ you'll be blinded at night when those lamps are lit! Even the normal sized main beam lamp is dazzling
yeah, but i've already got holes drilled in my dash i need filling.
hopefully i won't be seeing my oil pressure or battery light that often
Buy the set - Take the one you need and sell the others seperately on the Bay.
just got an email back, they are available seperately, £5.50 each though, but if they fill a hole... and look better than those black plastic ones
if you call them they will do them individually. they just haven't had time to update the catalogue/website yet
they print all the symbols themselves so can make what ever you like
[Edited on 9/10/09 by ashg]
take a peek in the Europa Spares catalogue or website - they may have some similar.
Another possibility is VWP.
Got a new and un used set of the 23mm chrome edged Europa jobbies - red blue orange and green As said above a bit bright unless dimmed down a
touch
in their catalogue as WL 26, WL28, WL29, WL25
£20 posted- Having a clear out so will stick them on end of the ad so as not to offend anyone
atb
Mike
