fireblade carbs (edited)
55ant - 23/11/09 at 10:24 AM
i have a set of fireblde carbs (with tps) with three wires on the left of the carbs, i have no idea what these are for, nor what to wire the to, does anyone know?
ok so the yellow circle is the three wires that i dont know what they are for
blue - is the fuel line
green - is a vent pipe.
red - vacuum pipe from engine block (in which you can put a catch can)
yellow - havnt looked at this one yet but does anyone know?
the pic is not my engine, but they are my carbs.
cheers, ant
[Edited on 23/11/09 by 55ant]
RAYLEE29 - 23/11/09 at 10:49 AM
Hi, the big black hose on top is the vent tube as for the wires cant see which you mean where do they go?
Ray
andrewcutchey - 23/11/09 at 11:05 AM
They are for the TPS which you do not need with your dizzy. Tie them off though as you may want them later if you change to megajolt.
Andrew
GreigM - 23/11/09 at 11:16 AM
I think the yellow line points to the accelerator cable...
Andy B - 23/11/09 at 02:27 PM
Red is float bowl vent pipes - leave open to atmosphere unless forcing the airbox in which case plumb it into airbox
3 wires on the end have been correctly identified as TPS which feed signal to ecu on 96 to 99 carbed blades
regards
55ant - 23/11/09 at 04:10 PM
okay, so where does the oil/vacuum hose from the block go? theres no fitment on the manifold, as there was on the downdraught manifold.
jacko - 23/11/09 at 04:54 PM
If you mean the breather pipe remove the one way valve by cutting the end off the valve will come out than the pipe wants to go to a oil catch tank
