side lights
bj928 - 16/12/09 at 12:26 AM
can i wire the side lights all on 1 fuse or do they have to be wire and fused left and right or maybe front and back.
blakep82 - 16/12/09 at 12:29 AM
as far as i know, you're allowed to put the on 1 fuse (same with dipped and full beam) but makes sense to wire them left and right seperately. if you blow a fuse you don't want to lose the lot
l0rd - 16/12/09 at 06:29 AM
more fuses = more weight
adithorp - 16/12/09 at 08:25 AM
Hmm...Good point. You wouldn't want to overburden that engine!
Yes, you can use one fuse but seperate left and right circuits is more usual.
adrian
l0rd - 16/12/09 at 08:49 AM
adrian
I see your point, but if you consider the complexity of the wiring diagram and the weight gained from fuses, wiring etc... -0.0001 Hp losses
[Edited on 16/12/09 by l0rd]
turbodisplay - 16/12/09 at 11:37 AM
Side lights, single fuse. Dipped and main beam seperate fuses left and right, giving 5 required.
Edit : Not the law, but makes a lot of sense.
Darren
[Edited on 16/12/09 by turbodisplay]
speedyxjs - 16/12/09 at 12:31 PM
I have sides on one fuse and H/L on one fuse (hadn't thought about losing them so may rewire yet)
bj928 - 16/12/09 at 05:36 PM
thanks for the replys, now i know what i'm doing.
