hello, i have a sierra steering colum, and would like the standard stalks for full beam and indicators, is this possible? if so how do they fit i will
get some pics of the column i have ,
thanks
i will get some better pics tomorrow,
thanks
the should be brackets on the colum part look like your have been cut off
[Edited on 25/12/09 by doddy]
I think if you have a look at "Car Builder Solutions" they do an indicator stalk that clamps on to round tube, then you only need to sort out some way of doing the lights. HTH Ray
But unless you have another motive for using a "bare" column just get another, complete with switchgaerf and steering lock for £20ish
you only need to change the outer part of the column.
sometimes come up on ebay.
you can retain your modified shaft.
