Happy new year all,
I know this is covered in many previous posts, but I haven't been able to get to a clear answer..
After moving my V6 g'box back to get it to fit and getting a clash of the cable to the chassis, I have got hold of a telemetrix electric speedo
(smiths) and have an induction sensor - but i'm not sure where to mount the sensor.
I have push in drive shafts so can't add a toothed wheel at the output of the diff. I think this leaves me with doing something on the prop or
the diff input flange....?
Can I get away with using the diff bolts as pickup or is there another 'technique' i am missing?
My understanding is that induction sensors are effected by the presence / moving of ferrrous - does adding magnets make any difference?
Greg
Have you thought about using the prop shaft bolts instaed of magnets? Works fine on my car
thanks - I have done - where have you positioned your sensor? - coming in from the side or lengthways?
Fitted mine lengthways using a small bracket bolted to the diff . Make sure you tighten the bolts so that the hexagon is in the same relative position to the sensor as the prop rotates to get a smoother signal . Thought I would try it after reading about all the problems with magnets flying off .
have looked at posssibility of using gearbox sender takeoff?
Burton Power send adapter for Ford gearbox.
You can mount the sensor on the front upright picking up from the wheel studs.
[Edited on 1/1/10 by hicost blade]
I have push in sierra driveshafts and a bicycle speedo.
I simply mounted a magnet onto one of the "metal beans cans" using a pair of jubilee clips. The magnet was out of an old hard-drive.
I would have used the propshaft bolts, but my bike speedo had a minimum "distance traveled per pulse" which was too high to do this.
At SVA it was difficult to calibrate the speedo, because their rollers allowed the rear wheels to rotate at different speeds, and reports the average
of the two (my diff isn't lsd).
Matt
At SVA it was difficult to calibrate the speedo, because their rollers allowed the rear wheels to rotate at different speeds, and reports the average of the two (my diff isn't lsd).
Matt
yes - unforutnately my chassis clashes with the g'box at the takeoff point so would be no-go. - thanks for the suggestion mind!
