I had an auto spark look at the problem with my indy and he couldnt find what was wrong.
Basically, i have a smithes rev counter gauge and i have an elecltronic gauge by translogic which tells me what gear i am in and the revs.
I cannot seem to run the 2 together, i have piggybacked off the wire going in to the translogic gauge and when i do that it shuts off the smithes
gauge and then only the electrical one work, then you plug it back out of the translogic one and the smithes gauge works again.
I plugged the wire out the back of the smithes gauge and in to the translogic one and then that works so it is the correct wire.
Does anyone no the problem and what i need to do??
Have you tried two wires from the coil, it souns as though your running the gauge in series ie one through the other which may affect the pulse going to the rev counter (smiths)
the coil? where would that be?
We need to know what signal the smiths and the other guage requires - do you have this info?
Presumably both connect to the switched terinal of the coil.
Does the engine run properly when both guages are connected?
Are you able to post photo of the rear of the smiths guage - does it have model number?
