Has anyone managed to bypass the security system without having the red master key for the kawasaki zx10r.
Got the complete harness including the cdi unit, ignition switch with black key but no master.
I thought there may be a simple way to do this without having to have a different cdi unit.
who did you get your engine from?
i got mine from malc at Yorkshire engines and the loom appears to be us spec with no immobiliser
I have both red and black keys. fitted the loom and cdi and immob amplifier and I have only ever used the black key.
It would appear from the workshop manual that unless you have the red key it will not start. I may be reading this wrongly, it would'nt be the
first time. However I do believe that the us spec cdi will be ok as I don't think it has the security modual.
I have used Trackelectronics before for a harness for a gsxr engine and he did a brilliant job and did tell me at the time that he could supply us
spec cdis, all I wanted to do was save a little money and perhaps learn something.
Good ! I was already worrying I wouldn't be able to start the engine. Track electronics are selling non security ecus for most japanese bike engines, check it out.
Hope that helps
So long as you have the correct key for the ecu ( as they are matched) and the key reader it should not matter what colour key you have it will run.
The red master key is the one that you have to present to a dealer to get a duplicate, if you dont have the red key for god sake dont lose the black
one as you will not be able to get a replacement.
As far as ecu's go there are only 2 that run without immobiliser - american or kit race ecu - however it would appear that a chap in poland has
found a way to reconfigure keys to ecu's but I dont know how he is doing it
Hope that helps
I'm using an American loom and ECU on mine, only thing needed to run is 100 ohm resistor fitted same as in zx9 wiring
Hi Andy at AB is correct the red key is only used for reprogramming new keys
us spec ecu,s are full power so no issues there either
i have also just found out how to re programme immobilised ecu,s and can supply keys to fit blank or cut to lock for £185 so this is a option
if you have lost all keys
cheers malc
