This problem was already there before I redid my whole dash. Oil gauge goes up to the top when ignition switched on and then moves down with the
engine started and more with revs. Tried connecting the gauge different ways (3 wires) one = nothing, the other stays at the bottom until first revg
them goes to the top and stays there. There is a fat black, thin black and thin red wire.
Any suggestion?
Which sender have you used? does it have 2 terminals? I ask as it sounds like you have connected your gauge to the oil wanring light. and not the
gauge sender
Regards
Bob
This is just a guess but assuming its not the original gauge to what your engine would have had originally, i would think it is due to the resistance
it works with abit like fuel gauges that come in (i think) about 100 and 510 ohms.
May be completely wrong though
Ermm dont know the answer to that. I bought the car built. Its a ZX9R so definitely new gauges when built.
As I said.. it DOES work.. just in reverse
(and before anyone says drive backwards.. I cant hehe)
[Edited on 28/1/10 by FFTS]
I would suggest a sender to gague mismatch
Originally posted by FFTS
As I said.. it DOES work.. just in reverse(and before anyone says drive backwards.. I cant hehe)
Would the sender be an engine specific fit or generic? If it will fit in a zx9r then I'll get one.
the sender itself is generic.
might be worth a call to rally design (or whoever you decide to buy from) to check the thread on the sender, and the thread on your engine.
Hello
The sender should look like this:
http://www.revotec.com/details.asp?ID=286
if it doesn't then it's the wrong sender for the gauge
and the instructions look like this:
http://www.caigauge.com/page19.html
[Edited on 28/1/10 by hicost blade]
