Can someone help me source a universal fuel tank sender to work with an acewell dash.
My tank is 200mm high.
Mikkel
Acewell do one of their own, tho' it's not cheap at £39.95, I'm away on hols at the mo, can check dimensions on my return next week.
Russ
I used a Sierra one with mine.
Having a quick look online the acewell one only goes to 128mm deep? Can this be right?
Is it able to be bent a bit to make it the right shape?
Although ideally looking to have a cheaper (£20ish) universal one that will work?
i bought a marine fuel sender they came in all different sizes, i'll try to find a link to show you
http://www.marinemegastore.com/product.asp?pf_id=AQU_Q96272&jump=4&cat_id=ENGINS004&cid=IXPD2L0CXCCA06D9H8OT8FBUZFDFZ4Y2
but i found somewhere a bit cheaper than this but can't for the life of me remember where
[Edited on 17/2/10 by prelude1980]
I bought mine from BanditMania, £30ish and had to make a new arm to suit the fuel tank. The sender unit has to be a 100 ohms (from memory) to work
properly. I couldn't find a universal one with the correct output.
HTH
OK thanks will look into it
