What diode exactly would i want to put in a line to stop earthing back when off. This is for the fog as when switched on the relay for the headlights
is earthing back when the lights are switched off.
I could get one from Maplins but being a bit dense dont know exactly what to get.
[Edited on 23/2/10 by Lightning]
3 amp would do it. about 30pence if i remember correctly
I'll have to save up then
Originally posted by Lightning
What diode exactly would i want to put in a line to stop earthing back when off. This is for the fog as when switched on the relay for the headlights is earthing back when the lights are switched off.
I share Craig's curiosity. Why would you want to put a diode in an earth circuit? If you have a high potential earth then it's most likely
caused by a high resistance joint (bad connection) or under-sized cable. You do sometimes need to put a diode across an inductive load (like a relay
coil), but this is a dymanic effect to allow dissipation of stored energy when you switch off the circuit. But your problem sounds more like a static
problem.
Someone educate me, please.
Any help would be greatly appreciated. I did this based on other threads. If its b*&%$ks then could you mark what you would suggest. This is one of only a couple of things to do before IVA
Are you trying to only allow the fog lamp to be switched on when the headlamps are on, or just the sidelights?
If the latter you should be grounding your fog lamp via the brown ground wire. The Brown/black is grounded by the headlamp switch, or in your case by
the fog lamp bulb.
[Edited on 24/2/10 by MikeRJ]
well got my 23p diode today and it now all works fine. No fog light until the dip or main beam on. Possibly not the best solution but what the hell it works.
