Cortina light / wiper stalks wiring
madrallysport - 23/3/10 at 12:42 PM
Guys wiring up my dads spartan kit car with a premier loom. I'm after the pin outs / wire colours for cortina stalks any help would be great.
Thanks in advance
Davy
robinj66 - 23/3/10 at 09:54 PM
It's probably not much help but my haynes manual shows the following for a Mark 4 2.3 car :
LIGHTING SWITCH
Pins 15 & 30 - red wire --- battery positive
Pins 58 & 55 (a)– grey/black wire --- fused live
MULTI FUNCTION SWITCH (HORN & INDICATORS
Pin 56b – brown(?)/yellow wire --- fused live
Pin L - black/white --- indicator bulb (l/h/s)
Pin R – black/green --- solder joint --- hazard switch + indicator bulb + instrument cluster + earth
Pin H – red --- hazard switch + fuse live
Pin H – red/grey --- horn
Pin 49a – black/white/green --- flasher unit
If you pm me an Email I will try and scan the diagrams for you. At some stage I will also check the wiring on my cobra but that will probably be at the weekend
madrallysport - 24/3/10 at 08:43 AM
Cheers Robin thats a big help
