Dropping voltage
scutter - 27/3/10 at 12:03 PM
Ok Lecky types.
I need to drop the 12v power supply coming out of the relay down to 5v for my VVC solenoid.
The simplest discriptions please
ATB Dan.
thunderace - 27/3/10 at 12:24 PM
go to maplins and buy a Resistors ,
to make it 5v
costs about 50p
MikeRJ - 27/3/10 at 12:45 PM
Are you sure your VVC solenoid is really 5v? That is pretty unusual; sensors often run at lower, regulated voltages but actuators almost always run from 12v.
Note that a resistor can not provide a fixed voltage drop unless the current load is constant V=IR. However, for a simple solenoid, a series resistor will be adequate as you simply need to limit the coil current to a sensible value. You will need to determine the resistance of the solenoid coil to calculate a suitable resistor value. It may be written on the solenoid itself, if not use a decent multimeter and measure it.
richardlee237 - 27/3/10 at 01:24 PM
Fit a 12v / 5v voltage convertor, cheap and simple, just make sure it can handle the current.
rayward - 27/3/10 at 01:25 PM
yeah as said, check it really is 5v, does sound a bit odd?
i might have something lying around will check
Ray
scutter - 27/3/10 at 03:52 PM
I got the 5V information from the end of THIS thread.
ATB Dan.
Dave Bailey - 27/3/10 at 10:47 PM
I have an ST170 Engine in my velocity and I am using a DTA ECU.... They have a config for driving the valve....... I am pretty sure it is 12V......
I haven't tested mine yet....
Dave Bailey
scutter - 28/3/10 at 08:16 AM
I'll use 12V to start with, to keep things simple. I assume the solenoid will just get hot with 12V?
ATB Dan.
splitrivet - 28/3/10 at 05:34 PM
A 7805 regulator IC is the easiest way but sounds a bit odd .
Bob
scutter - 28/3/10 at 07:00 PM
I've been out and checked the solenoid has 5V written on it!
ATB Dan.
Dave Bailey - 28/3/10 at 08:15 PM
You have me worried now..... I was told by DTA to use an AUx input that sinks 12V... I need to check with DTA tomorrow....it may be that they wanted me to use this input but driv eit from 5V...
Dave B
02GF74 - 28/3/10 at 09:13 PM
car electrics run closer to 14 V.
remember power = V squared / R
so by almost tripling the voltage, you are dissipating close to 9 times the power it was designed to handle.
I doubt it will last long - I would not recommend.
depending on the current, then a 7805 on a heat sink would give best regulation;
cruder method, as ^^^^ said, is resistor or use diodes to drop the voltage.
scutter - 28/3/10 at 09:16 PM
I'll switch it down
Dave, would you be able to check your solenoid? I'm pretty sure the top line had 5V in it.
ATB Dan.
ss1turbo - 5/4/10 at 08:15 PM
It may be getting 5v via a PWM signal originally, but some engine electrics do use 5v reference signals (TPS, temp, etc). It all depends on the power/current requirements of the solenoid though - I've got 5V coming off a 12v/USB cig lighter adaptor, but only at about 1A or so.
