Sierra column wiper connections
Paradoxia0 - 28/3/10 at 09:35 AM
Hi Guys,
This is doing my head in.....
I have purchased a windscreen wiper kit from CBS and I am trying to wire it and all is good, except it won't park. The destructions state:
Mini and Ford wiper switch feeds +ve to Red/Green when switched on but links Red/Green to Brown/Green when switched off to power self parking.
The pin-outs are (with normal colours):
1. Earth (Black)
2. Self park (Brn/Grn) (When switch is off this connects to terminal 5 (Red/Grn))
3. Wiper fast (Red/Brn)
4. Fused ignition +ve (Green)
5. Wiper slow (Brn/Grn)
It is terminal 2 I am struggling with.
I seem to rememeber on the wiper stalk there was a link cable between one of the spade on top and somewhere else and I guess that is the bit I am missing, but I have run out of fuses now and am getting rather frustrated...
Can anyone help? Any ideas what I am doing wrong?
Mark
PeteS2k - 28/3/10 at 10:36 AM
Try this
http://nw.rhocar.org/mini_wiper_motor_wiring.htm
It's what I did. Couldn't fathom it myself, so just followed the 'connect A to B' from the above guide...
ReMan - 28/3/10 at 10:38 AM
Are these the switch connections?
1. Earth (Black)
If so Then
1 is obviosly earth,
4 is power in
3 and 5 go to the motors fast and slow connectors
2 goes to the motor self park connector, BUT, unless the switch is linked internally then this may need the link wire yo describe between 2 and 4
PeteS2k - 28/3/10 at 10:45 AM
Actually, I've just found the actual diagram I used and posted it in my Photo Archive. Dunno how to pate the image directly here...
Assuming it's the same sort of wiper motor...
RichardK - 28/3/10 at 10:46 AM
Wiper Wiring
Wiper Wiring
Paradoxia0 - 28/3/10 at 10:56 AM
Thanks guys, I'll go give that a go!
(the misses has complained about the swearing from the garage so I think she will be grateful too )
Mark
Paradoxia0 - 28/3/10 at 12:12 PM
Fantastic!!!!
Finally got it, thanking you very much indeed!
(turns out I had wired the switch wrong about 3 years ago whilst building which as it hasn't been used until this weekend hasn't been an issue!)
Mark
