Hi all, can someone tell me if the rear reflectors have to be a certain distance from the rear lights, or are these all in one lights i.e
stop,tail,indicators and reflectors ok that are in the picture below
Doant alot of factor cars have reflectors in. Mk5 Fiesta for starters.
So I would of thought they would be ok. In terms of reflectors that is.
stick on ones can be put them next to the lights on the arches just make sure they are at least 350mm above the ground and dont stick off the surface
more than 5mm or they can need to be radius proof ( i.e have a 2.5 radius on them)
as long as those ones in your clusters are more than 350mm from the ground ull be fine
[Edited on 30/3/10 by jack_t]
it'll all be in the iva manual
