Slightly OT...
But I am fitting a leisure battery into my sisters van at the moment... It charges via a cunning voltage sensing relay which contacts when the engine
is running..
thats simple..
BUT..
My sister is a bit of a muppet sometimes... chances are she might accidentally leave the lights on in the camper, or leave something plugged in
etc..
Is there a device which can be made/purchased that sits between the battery and the "load" that cuts off supply when the 12V leisure battery
starts to drain out? (I guess triggering around 10.5V?)
All I can find on ebay are 20A battery guards... but 20A is a bit low... and they look like they might get pretty hot!!
Any thoughts?
[Edited on 1/4/10 by tegwin]
ooh, my dad america ford aerostar used to do that. when the battery got to about 10v, it cut everything off so you could still start it.
so i guess it can be done yourself, i don't know how, but they system is out there, and this was a 1986 van
I would've thought that pretty much any of the camping/caravan outlets would stock something designed for this application?
Ed
but isnt the whole point of the leisure battery the fact that it doesn't matter if you drain it (aslong as your not repeatedly deep discharge it?)
use the battery guard to drive a larger relay?
use several battery guards or just put the circuts likeley to be cause problems (lights etc) on it and keep other things directly connected?
Why not fit one of those solar panels that charges the battery during the daytime? Most of them plug into the ciggy socket but i have seen them disquised as spoilers, scuttle panels etc
We use these at work and they seem to do the job OK. Intellitec battery gaurd
Our 2008 Jeep Wrangler has something like that, I can leave all the lights on and walk away, they go out by themselves about 10 minutes after.
One click of the door open fob and they all come on again. It's a security vehicle so helps out on very dark nights.
