Hi,
I dont fancy drilling my tank now its full of fuel vapours etc... but not having a fuel gauge is a bit of a pain! Seriously considering taking a jerry
can everywhere with me
So folks - how can a fuel sender be retro fitted? are there any ways that avoid drilling it?
cheers
Should be ok drilling, just take it nice and slow. Is it ali, steel or plastic?
Rich
Rich
I wouldn't worry, just nice and slow, chain drilling with a nice, small bit would take longer but wouldn't generate as much heat if any,
that's if your drills are nice and sharp.
Rich
If you are really concerned, an old trick is to run the exhaust from a vehicle in to the tank while you do the work, dilutes the explosive gases.
You could also use an air drill or hand drill to keep electrickery out of the equation
should be fine i'd say.
what i'm planning on doing, is not having a gauge, but you can get optical liquid sensors from RS, one or two of those near the bottom of the
tank will light a LED on the dash to show fuel's getting low.
think this was the one
i bought a 2nd hand fuel tank. it smells of something, not really petrol though. weird. but the first thing i did was remove a bracket i didn't
need, ground it all off with the grinder. got very hot
because alu doesn't glow when its hot, i didn't think and grabbed a hold of it.
burned my finger prints off
[Edited on 3/4/10 by blakep82]
Same situation as me - except mine is plastic.
I am more concerned about the small particles and shards entering the tank from cutting. Any ideas how to avoid this ?
I was considering emptying the tank, removing, drilling, then flushing, drying completely and then refitting ?
Again I wouldn't bother if you've an inline fuel filter, just run it empty a couple of times then change the filter.
That's what I'd do, but there again I am a lazy bugg3r.
Rich
