I've just bought some mirrors from Europa with built in LED side repeaters. These have 3 wires coming out and the following instructions:
Blue, connect to (+) packing lamp
White, connect to (+) single lamp
Black, connect to (-) vehtcle round wire
What does this mean in English??
Confused of warwickshire
black = earth
try the others one at a time using a connection to the battery
Not good on leccy bits like this either
Yeah. I'd worked out that:
Black, connect to (-) vehicle ground wire
Fiendishly cunning these orientals!
you may still need other side repeaters if the ones in the mirrors can,t be seen from the correct angle from the rear, ( mate had same problem on his
cheers
andy
"you may still need other side repeaters if the ones in the mirrors can,t be seen from the correct angle from the rear, ( mate had same problem
on his )"
But I've already got SAV
Obviously I meant SVA!!!
Originally posted by Alan M
Obviously I meant SVA!!!![]()
"you may still need other side repeaters if the ones in the mirrors can,t be seen from the correct angle from the rear, ( mate had same problem on his )"
But I've already got SAV![]()
Hi
Just a stab in the dark .............
Blue - parking lamp
White - signal lamp
Black - vehicle ground
Regards Mick
