im just having a thought....
600 pounds for a reverse box is not an option at the moment, so im looking at using a starter motor....
however, i dont want to run this on the bike battery so could i fit a small alternator to run off the rear diff flange to charge a seperate
battery???
cheers
barry
[Edited on 23/4/10 by boggle]
Space is at a premuim so stickin more stuff under the rear is a no no.
Cant you hire borrow one of some one...just for the test...same as the catz
the usual way is to stick a motorcycle starter motor on a cog at the top of the rear tunnel.
that will require a small jap battery to run it.
Using a bike battery is a poor move as we have found. The first time you lay the car up for a few weeks you need a new 50 quid battery.......
car is allready legal...i need a reverse for hillclimbs and the misses......
Originally posted by boggle
car is allready legal...i need a reverse for ... the misses......
Fit a split charge relay, then the two batteries are kept charged but are on seperate circuits
Get a proper engine you Jessy.
