Hi,
I have just installed a fuel sender but it doesnt marry with my gauge (it reads back to front!!) does anyone know what gauge runs on the opposite to
the cai gauges?
I know I could just install it as i know its wrong but I would like it to be correct!
Instructions are on there website. you just unbolt it and turn it upside down.
edit ok not on the website but it is in there instructions.
You will have to bend the float a bit.
[Edited on 30/5/10 by big_wasa]
Robin hood used to sell a sender that worked back to front and the simple solution was to remove tha sender carefully unclip the circuit board reostat
unsolder the wire and resolder to the other end of the board.
I did this, it's a simple job and works quite well
The sensor just unbolts from the rod. Its one bolt. Just turn it up side down.
Sorted cheers guys it was as easy as un screwing and turning the little circit bord arround to face the other way!
