beccy fried wires
Hooooooray... I'm an auto electrician
looks a tad messy that
Switch your meter to amps, as high as possible, and test those two reds which are hanging under the driver side of the dash, if they no longer send
the meter off the scale, you've cracked it.....
Meter positive to battery positive, meter neg to thos reds one at a time.
Cheers.
Pete.
I'm not sure but I think you might be onto something Watson
Just how on earth did you miss that big red jack
that would short it out for sure
mice
Originally posted by r1_pete
Switch your meter to amps, as high as possible, and test those two reds which are hanging under the driver side of the dash, if they no longer send the meter off the scale, you've cracked it.....
Cheers.
Pete.
only kidding. Don't think you will get the smoke back into those
even with this kit
Cut the red wire... it's always the red wire!
how can you be so certain that it came from there?
shiny new wiring
and yes I have tucked and strapped all away before someoen tells me I'll catch it on something
Originally posted by FFTS
beccy fried wires
Hooooooray... I'm an auto electrician![]()
beccy fried wires
As Britney once said "Oops I did it again"!!
Can I have a job at yours then Monday to Wednesday
