Getting headaches trying to find a whole set of lights!
I quite like the hella mix and match ones from SVC but there not exactly locost at about £155 at set and with no pods so i'm not sure how they
mount(normal indicators with LED brake tail outers as it saves sorting resistors etc!)
Has anyone used a set of the above with pics?
However I also would like the landrover 3" style ones, 3 per wing in a row but I think it could look a little too busy?
Fronts I'm quite keen on the black oval ones for some reason.
Can anyone provide me some inspiration?
I recently bought soem new rear light clusters from CBS for £35/pair iirc and I'm sure they do some nice smallish h/lights for sensible money
too. Then you just need front indicators (from a bike) and repeaters.
Simon
I got a set of the 95mm ones that SVC sell - I wasn't planning to have any pods as such, just cut a hole in the wing and fit them in (sound easy
when you say it quick - not fitted yet though
1 pait of clear indicators
1 pair of stop/tails
1 fog
1 reverse
@ £25ish per pair, so £75 all in I think (I got them at stonleigh so I don't remember exactly)
iiyama has similar ones on his dax (all be it with different style of lense to mine)
[Edited on 24/6/2010 by mcerd1]
If you use a flasher designed for LED's you don't need to muck around with resistors - which are an expensive way to save a couple of quid.
Have a look at my photo link, you will get an idea about the rear lamps etc & whether you like them, they are landrover lamps, Dennis.
http://s836.photobucket.com/albums/zz286/drury318/
Really cheap too, from ebay but I don`t recall who from?
[Edited on 24/6/10 by drury318]
http://www.twenga.co.uk/dir-Cars-Motorbikes,Car-ignition-lighting,Rear-lights-6716
I can't remember the site, but they were even cheaper somewhere else. Bound to find something not too pricey if you look.
