I know this has probably been asked loads of times on here before, but does anyone have a wiring diagram for the hazards using a single pole switch? I
am using this swich; https://www.europaspares.com/ELECTRICAL/SWITCHES/LED_HAZZARD_SWITCH_RED___WL4014_6538.html
I'm strugling to find a suitable wiring diagram that shows the relay conections, the car is using the std bike loom, i've just lengthend the
areas that I need to.
I might be wrong but the switch looks like it has one feed in and 2 feeds out for LHS & RHS
If this is the case then one of the 3 goes to the relay and the other 2 go to the lights.
Relay will have 3 pins, 12v Permanent live, Earth & the feed to the switch.
Pretty sure this is how mine is wired and it works.
Will it not need a canceling circuit for the indicators?
This is doing my head in now!
I've spent an hour searching the net for a wiring diagram and found F@#k ALL! so it looks like another day
wasted doing nothing. Over the last few weeks I seem to take one step forward and three steps back, I'm ready for setting fire to this bloody
thing, I bought some harnesses last week and found that the lap straps are too long-despite moving the mountings back by 6"
anyway rant over I'm going to the pub F@#k it!
I'll try and sketch out my wiring for you.....
Here you go, this is how mine is wired...
If you still want to use the switch you have then you might need to use diodes to keep the LHS & RHS cercuits seperate.
cheers for that mate, think I might have sorted it.
