Hi all,
I now have pretty much everthing working on the car but can't get the ETB Digidash Lite to read RPM from the MS ECU. It's an Extra EFI MS1
V3.0 with Tacho Output.
Any ideas??
Matt
Don't mean to hijack thread but i also have this problem with acewell and omex ecu.
Are you running EDIS?
no not running EDIS....running wasted spark controlled from MS.
Thanks,
Matt
Same problem with my Acewell.. sorry to say its connected to the EDIS and works now.
Is the RTB tach input designed for ECU or coil?
I can make you one of these if you want.
4th item down
£5 posted
[Edited on 12/7/10 by Snuggs]
Snuggs.......If it works then I'll take one. I have a single Tacho output from the MS and a single input to the Digidash. So in my case how
does it connect up and do you know if it works with the ETB Digidash lite??
Matt
4th item down
£5 posted
Originally posted by Bumble
Snuggs.......If it works then I'll take one. I have a single Tacho output from the MS and a single input to the Digidash. So in my case how does it connect up and do you know if it works with the ETB Digidash lite??
Matt
4th item down
£5 posted
Matt, You have U2U
Clive
