I am just finishing work on my Velocity electrics. How do I need to wire the two items above? do I wire the two into the warning lamp for the brake symbol on my bright 6 display? Any advice is much appreciated.
Hi,
Both wires connect to the display so either will light up the bright 6.
Darren
Cheers Darren
Fused +ve to the light and then one wire each to the level and handbrake switches then to earth from each switch.
adrian
