Where could i get a rubber boot to cover all the wires that go into the ecu Or do i needone for the iva?
200sx s14a ecu
I stock several sizes of gland nut covers I use for track rod end covers & similar, give me an idea of size & I can give you a price.
about 5inch x 1 inch
www.polevolt.co.uk have most things. I just bought £60 worth for my engine.
tried polevolt just not the right size................
& re "do I need one for IVA" depends entirely on the tester on the day some can be very picky others much more laid back
Guess i need one then about 70 wires coming out some of them cut not needed etc
russbost clutch pies worked out well ... cheers
what happened to the std one that was fitted to the ecu loom?
the one on my s14 ecu came with one
never had one!!
