Am going to try and make a wiring loom from scratch, cause i know absolutely nothing about it. And since all this is a major learning exercise, I
think its worth a go. so question's
Anybody used this westfield diagram to wire the entire car
http://westfield-wor...ing_frames.html
would it be ok?
go for it. I used it some of it but i think it pretty good , had to mix mine with nissan wiring loom
I'm probably selling my MK loom pretty soon if it's any good.
I had a look at it, its not bad but the fog light needs some work to only come on with ignition and main lights on.
Its very easy to make a loom. Just run one thing at a time and and test it.
I started with the indicators Hazard's ect.
I can't get your link to open Femster...
^^^ me either
Have a look at the one's on Polevolt's website I used those but there are one or two things missing but it is a good start and you can
easily add to it,
RD
THIS is just one sheet
[Edited on 5/10/10 by rallyingden]
ok, gonna get some wires ordered tomorrow. and let you know how i get on. ok I would note the fog light bit
try this
http://westfield-world.com/techelectric.html
its the new wiring diagram
Just do one circuit at a time, and test it before you move onto the next one.
Just don't use all one colour!!! You'll never fault find later.
