Fitting LED rear lights
speedyxjs - 14/10/10 at 07:35 AM
Now that i know i have to change my lights (should have checked about the triangular reflectors) iv been looking at LED ones like these but these would make the indicators flash really fast.
Am i right in thinking i can just fit an electronic relay and they will be fine?
Stott - 14/10/10 at 07:48 AM
Yeah, the type that's on ebay called multi load or something, they look the best to me, if you swap a couple back to filament lamps later on it'll still run them.
It's about £15
EDIT: Dual Load, here:
[url=http://cgi.ebay.co.uk/DUAL-LOAD-LED-FLASHER-RELAY-3-PIN-L-E-D-FLASH-RATE-FIX-/180531818850?pt=UK_Motorcycle_Parts&hash=item2a0888f162]LINK[/u rl]
Might be cheaper elsewhere I haven't really looked.
EDIT 2: Don't know why that link doesn't look good - confusing
HTH
Stott
[Edited on 14/10/10 by Stott]
scootz - 14/10/10 at 08:20 AM
I've not got as far as wiring them yet Speedy, but I have a set of those and they are pretty nifty little things!
bbwales - 14/10/10 at 08:34 AM
Fitted those lights to my nephews trike, they work well.
I have LED lights on my car and used a motorbike electronic flasher unit from Halfrauds works well and as said above if a bulb is put in the cct after then the flash rate stays the same.
Regards
Bob
emsfactory - 14/10/10 at 08:42 AM
I am wiring a set of those at the minute. Got the tail lights working last night. hope to get the indicators going by the weekend..
I can let you know if there are any problems.
speedyxjs - 14/10/10 at 10:13 AM
Cool, thanks as ever guys
Hellfire - 14/10/10 at 08:01 PM
Or
DIGITAL UNIVERSAL FLASHER RELAY AND INDICATOR BUZZER on eBay (end time 22-Dec-10 16:27:22 GMT)
Incorporates a buzzer to remind you of the indicators left on - wind noise and sun hide the clickety thing...
emsfactory - 20/10/10 at 08:46 AM
Yep wired mine up and they blink too fast.
Have ordered a multi load relay.
Will update with results.
emsfactory - 22/10/10 at 01:47 PM
Fitted the dual load relay and all is now sorted. Just make sure you get the same one as you allready have.
