AGAIN!!!! I have a wiring diagram that shows a seperate fuel pump and relay, my 2001 loom appears to only have one plug. It has the fuel pump bolted to the throttle bodies, so, should it only have the one plug?
mine does and works fine with the original pump and a low pressure pump feeding the swirl pot.
I have removed what I thought was the side stand/flasher relay and I think that may have been fuel pump too?
problem solved... my wiring digram is wrong, 1 plug to throttle boddies and then there is a seperate loom from that to the pump! phew!!!
