evening all,
i am looking to add in an FIA cut off switch in the car, from my understanding of the wiring diagram i need a cable to run from the battery to one
side of the switch and from the opposite side i need to run 1) a cable to the starter motor, 2)a cable to the ignition barrel and 3) anything else
that i want to run with a perminant 12v. e.g horn.
now im not sure what size cable i need to run for either of the sides of the switch, so can anyone shed any light.
the switch is a 1000amp FIA Approved cut off switch (but im sure the starter won't be using in excess of 1000 amps
so what currents should i expect to see in the following wires.
1)from Battery to Cut off switch (During and not during cranking)
2)from the switch to the starter motor (current during cranking, (at a guess 200-300amps???))
3)the size of the cable needed from the switch to the igntion barrel (i would hazard a guess and say 16amp should be fine?)
thanks in advance for any help
Alex
won't be any higher than what's written on the battery
at a guess 350 - 400 amps would be as high as you'd normally expect
As a (very) rough guide, you need around 1mm^2 of wire cross-section per 5-10A. No idea how much that is in SWG.
Use 1mm^2 per 5A for continuous loads (lights, etc.) and 1mm^2 per 10A for intermittent loads (horn)
evening all,
i am looking to add in an FIA cut off switch in the car, from my understanding of the wiring diagram i need a cable to run from the battery to one side of the switch and from the opposite side i need to run 1) a cable to the starter motor, 2)a cable to the ignition barrel and 3) anything else that i want to run with a perminant 12v. e.g horn.
the switch is a 1000amp FIA Approved cut off switch (but im sure the starter won't be using in excess of 1000 amps)
Alex
Don't know if it's allowed, but the easiest way is to fit the switch in the earth lead, that shuts everything down and it's just one wire. HTH Ray
