Mega jolt Maps
Barksavon - 19/12/10 at 07:08 PM
Im hoping to plug my laptop into my megajolt tomorrow. I'm new to mappable ignition, is there a map already loaded onto the mj ecu or are there ignition maps available that i can copy to the ecu or do i have to set up my own. I have downloaded the configuaration software from autosports labs...any advice much appreciated
ChrisL - 19/12/10 at 07:39 PM
There should already be one loaded.
SPYDER - 19/12/10 at 08:12 PM
Lots of maps at the link below.
Where in Derbyshire are you?
Geoff
MEGAJOLT MAPS
Barksavon - 19/12/10 at 08:19 PM
nice one thanks....in Alfreton
snapper - 19/12/10 at 08:42 PM
It should have a base map which is very safe for most engines, however it would be prudent to wire it up and use the tuning program to see what you have befor turning the engine over.
As a starting point you can set a 2 dimentional map similar to the engines original.
For the pinto something with 10 degs at start up and idle then going linier to around 36 to 38 degs 3600 revs.
There are maps on the web but the only a few and only once that have worked on specific engines, you will always have to rolling road you configuration
mcerd1 - 19/12/10 at 09:00 PM
what engine have you got ?
Barksavon - 20/12/10 at 09:12 AM
Its a 2.0 Pinto which is to be fitted with a Newman fast road cam, its got bike carbs fitted....Thanks
mcerd1 - 20/12/10 at 09:43 AM
u2u me your e-mail and I'll send some over
I've collected a few pinto maps you could use to get you started
SPYDER - 20/12/10 at 12:48 PM
I'm only ten minutes away if you need any help or a shoulder to cry on.
I'm no expert but I've managed to install MS on my car.
I've got a good timing light too if you need one.
It's a busy time of year but I'll help if I can.
U2U me.
Geoff.
steve8274 - 20/12/10 at 09:42 PM
Geoff
MEGAJOLT MAPS
do you know of anywhere that does maps for cvh engine?
cant seem to see any on that site
thanks
steve
SPYDER - 21/12/10 at 09:15 PM
There's a map for CVH using TPS on the AutosportLabs site.
More than one.
I would think that a Zetec map ought to be safe starting point for a CVH as well.
Geoff
CVH MAP LINKY
