I need the following sensors to work with an ST8100 dash...
Oil Pressure
Oil Temp
Water Temp
Water Pressure
Stack's sensor prices are a little... ahem... pricey, so just wondered if any other manufacturers sensors would work with it instead?
Cheeeeers!
I'm sure there was someone on blatchat (sorry it was WSCC) had used VDO sensors and found a good supplier, worth a search on blatchat.
Link sent u2u
Ian
[Edited on 26/1/11 by mackei23b]
Thanks Ian.
Will do!
Oil Pressure
Oil Temp
Water Temp
Water Pressure
Cheeeeers!
Stack sell the best products but they do seem to be very expensive. You want to look at prices if you go for solid state sensors for pressures
