Hi, all...
Looking for some instruments to use in a 7-style. Prefer individual dials to the all-in-one stuff, but new clocks cost an arm & a leg. Would
settle just for (electronic) speedo & tacho as long as they match, but nobody seems to have any. Apparently motorbike stuff is unsuitable as
well, which seems to leave just one option - a set of used car clocks.
So... what would folk recommend by way of a suitable donor car for something that looks nice & is easy to transplant? If they come in a binnacle,
how easy is it to separate them & then get hold of glass & IVA bezels?
Any help/suggestions much appreciated!
Acewell does a wide range of digital and analogue-ish instruments. With one of these and maybe a couple of extra
lights you could get by.
This one's got most things on it
rally designs RMD stuff is good!
£80 for the speedo, 60 for the tacho, ooh, plus vat though...
http://www.rallydesign.co.uk/index.php?cPath=412_1824_1879&osCsid=kt6sajjgj6v0h7fq9kq8tkna55
made by the same folk that make smiths gauges, which are real good
Elise/VX220?
sort of all in one but look very neat.
Paid £50 for mine (albeit later ones so couldnt get coolant gauge to work properly due to requiring a pulsed canbus signal) but the early (s1 elise
and i think its the NA VX220) use standard wiring methods. You just need a pulse feed for the elec speedo. I used a astra digi dash sender for mine
and ran that thru a adjustble pulse converter (picbits.co.uk)
[Edited on 4/2/11 by loggyboy]
I used a unit from an escort, chopped it about and fitted it flush to the back of the dash and made it look like individual dials with turned ali
bezels - ok for SVA.
My current Mk3 Mondeo has nice looking instruments in a unit but made to look like separae dials - you may be able to do the same trick
i plan to use the 7 gauge set from etb.
7 Set with mechanical speedometer = £249.00 (Includes VAT and delivery)
7 Set with Electronic Programmable Speedometer = £349.00 (Includes VAT and delivery)
For this you get :
80mm Speedometer
80mm Tachometer
52mm Oil Pressure Gauge
52mm Water Temp Gauge
52mm Fuel Level Gauge
1/8"NPTF Temp. Sensor
1/8" NPTF Oil Pressure Sensor
1/4"NPTF adapter (for oil pressure sensor to fit Ford block)
6-hole top-mount fuel level sensor
(plus hall-effect speed sensor & magnet kit if electronic speedometer set).
Black or white background dials, black or chrome IVA bezels
HTH
steve.
I am thinking the same, etb with electronic speedo. I wonder if they would do a bulk buy discount? If there was any interest, I could always ask!
Adrian
Adrian
For this you get :
80mm Speedometer
80mm Tachometer
HTH
steve.
It's called the '7' set!
Adrian
I would be up for a bulk buy from ETB. Gauges are tooooooooo costly, but I want them.
Started a new thread, could anyone interested put their names down on the new thread so that I can keep track!
Adrian
i have just looked at etb's guages, am liking what i see.
i currently have an acewell digidash which im planning on removing and putting in classic gauges. im not a fan of the digital speedometer though.
how hard is it and what is required to fit a mechanical one?
chris
