hey there, im trying to wire in an oil pressure sender gauge into my dashboard, the gauge and sender i bought were pretty cheap so sadly the instructions are crap. the sender has two terminals labelled G and WK. after a bit of reserch ive found that G should be wired up to the pressure gauge and WK is german for warning contraption, so im guessing its some kind of low oil pressure switch, (which im guessing would normally turn a light on the dash on at low oil pressure) i just wanted to double check i was right? what i plan on doing is wiring the G terminal of the sender up to the pressure gauge ( which only has 3 inputs, 12+ ground and sender input) and then i was going to wire the WK terminal up to the oil pressure warning light on my acewell digi dash. does that sound about right?
