ZX6R carbs TPS wiring
snippy - 17/3/11 at 05:57 PM
Just before I hard wire this all up properly can I check with anyone who is using ZX6R carbs with TPS the correct wiring configuration please. I`m using Megajolt ignition.
Megajolt black wire (Earth) to Black/Blue wire on TPS
Megajolt Orange wire (Return Signal) to Yellow/White wire on TPS
Megajolt White wire (+5v) to Blue wire on TPS
If I use my voltmeter across the Earth and Return signal wires when I open the throttle I am getting a voltage increase so I think this is all ok but just want to make sure before I solder it all up!
Thanks,
Nick
r1_pete - 17/3/11 at 06:14 PM
Don't know the colours, but the signal wire should connect to the wiper (centre connection on the TPS) and yes the voltage should increase with throttle opening.
r1_pete - 17/3/11 at 06:22 PM
whitestu - 17/3/11 at 08:37 PM
This might help
Click here
Stu
