Plug
plug2
its off a mk1 focus front fog light if that helps any....
Go a scrappy and just cut one off a cars loom with a short length of cable attached?
Yep, as above.
Either get one off of another car from the scrappies or cut that plug off and just use one of your choice.
I think you will be lucky to find a supplier of new plugs to fit that you can crimp or make up yourself.
HTH
Biz
looks like an EV6 plug as used on the latest bosch injectors. You can some times get them new on ebay or other electrical supliers.
compare ?
