Wiring battery to fusebox
JekRankin - 1/4/11 at 12:26 PM
Apologies in advance for what is a very basic question, but I'm a little stuck!
Just starting to have a look at wiring my car. My plan is to have four fuses in my fusebox fed directly from the battery with 10mm cable.
My question is, how do I physically make this connection? Running 4 separate cables to the battery seems a bit messy - is it normal practice to use some form of junction box near the fusebox to distribute power?
I've bought a book on Auto Wiring, but it doesn't have any mention of how this is usually achieved.
Jek
phoenix70 - 1/4/11 at 12:50 PM
10mm is a big cable, what I did was split the big cable into smaller sections and solder smaller cables from that to the fuses, then covered it all with shrink wrap.
40inches - 1/4/11 at 12:53 PM
Battery distribution box or Junction box
Or, if you already have a fuse box, run one cable from the battery to the first fuse, then daisy chain/loop along to the other fuses.
Crude drawing:
[Edited on 1-4-11 by 40inches]
snowy2 - 1/4/11 at 01:23 PM
as above for me......but it is tidier to take the live feed from the starter motor solenoid. also you dont want all your fuses battery live all the time or you wont need keys to operate anything. a wire of about 5mm diameter will be man enough for the electrics you need and in all honesty is bigger than you need, and bigger than i use. (i use some wire about 4mm diameter)
daviep - 1/4/11 at 02:23 PM
I'm guessing when the OP says he is using 10mm cable he is refering to 10mm cross sectional area which is about 4mm diameter.
Davie
britishtrident - 1/4/11 at 02:24 PM
Another way to do it is to take your feed from the battery to a high current rated Midi or Mega fuse in a single holder and feed the distribution fuse from that.
big-vee-twin - 1/4/11 at 04:42 PM
You need a couple of fuse boxes with 5-6 fuses in each, feed one with permenant live and the other switched through the ignition switch.
Ideally the cable feeding the fuses should be fused too, to protect the supply cable to the fuses, usually about 30- 40 amps depending what your connecting.
coozer - 1/4/11 at 04:46 PM
Get one of these off a Nissan Note in the scrappy.
4 fused outlets right on the battery. Get the connectors that go in them as well and your sorted.
[Edited on 1/4/11 by coozer]
JekRankin - 2/4/11 at 06:44 AM
Thanks for all the helpful replies, I'll have a look at all those options.
Sorry for not being clearer in my original post; the 10mm cable I was referring to was cable with a cross sectional area of 10mm^2, which as 40inches says, is about 4mm diameter.
I'm planning on having 8 fuses in total, with four permanently live from the battery. The remainder will be switched through the ignition, although the wiring for these is already complete courtesy of one of Eddie99's looms.
Jek
omega 24 v6 - 2/4/11 at 09:12 AM
I took the 10mm cable through a 70 fuse (midi fuse)and soldered it into a 8mm microbore copper pipe 40mm long. then took 6off or 8off 2mm cables out of the other end of the copper pipe to each fuse. covered it all with heavy duty and resined heat sleeving.
daviep - 2/4/11 at 01:38 PM
Jek
Who said that
40inches - 2/4/11 at 05:31 PM
Jek
Who said that
Wasn't me! you can't prove a thing
