Megasquirt on a V8?
coozer - 6/4/11 at 05:11 PM
'Squirt came off bumper today destined for the Jago with RV8 power..
Its an Edis version, question is will it run an Edis8 just as well as a 4 and will the two injector wires be OK for 8 injectors?
Paul (Notts) - 6/4/11 at 05:27 PM
Just finished converting my RV8 to megasuirt / edis 8.
Its should be fine running two banks of injectors (each of 4)
It will also run an eddis 8 as the only signals are pip and saw signals.
Be carefull of the Idle air control as it may need an external relay , unless Its been updated to handle the current. ( efi extra ones often have)
Paul
mark chandler - 6/4/11 at 08:05 PM
Does not look like you have the flyback board, need to use resistors on the injectors as PWM will not handle the load of 4 x 15ohm resistors.
I know from experince....
