indicators flash speed with engine on
locostbuyer83 - 19/4/11 at 05:54 PM
Just noticed that my indicators flash faster the more the engine revs. please could someone let me know how to fix it?
im sure im not the first one with this problem
westf27 - 19/4/11 at 06:01 PM
sounds like a regulator problem causing too much voltage.Meter test the voltage across the battery at idle and high speed.I assume that your flasher unit is loaded correctly with the right wattage bulbs.Alternatively slow down or dont indicate at high speed
britishtrident - 19/4/11 at 06:03 PM
Before doing anything to the flasher system I would put a voltmeter across the battery and check the battery/charging voltage at various RPM conditions.
westf27 - 19/4/11 at 06:07 PM
evening,its been hot down here,what about where you are
locostbuyer83 - 19/4/11 at 06:20 PM
put my meter on the battery and its consistent, doesnt go up and down much when increasing engine speed.
