Morning all
Need your help this morning. I'm trying to source a variable load flasher relay to allow me to use a mix of bulb and LED indicators. A Google
search brings up loads but they all seem to be for bikes therefore less bulb/LEDS involved. I'm only swapping the front indicators to LED so
there'll still be 5W side repeaters and the rear 21W to consider.
Any assistance on a 3 pin relay which will allow me to run LED and bulb at the same time would be much appreciated.
Many thanks and have a great Easter.
[Edited on 21/4/11 by jabbahutt]
I'm using LED on the rear with standard on the front and my 'normal' indicator relay works fine, so I would get them fitted and try it first.
got mine from ebay it says its a electric flasher relay and will flash at the correct rate on a total of 1000w ive got led at the front 5w on the sides and 21w at the rear and its works fine
many thanks for the quick replies
