Hi Guys,
My Setup:
Mk Indy zx12 engine
I have a loom for the engine and a separate loom for the lights etc
Using fiesta mk3 stalk for lights and indicators
Everything works fine however the indicators don't!
indicator bulbs used:
2 rear 21w bulbs
4 side repeaters (small bulbs)
2 led front indicators with those relays or whatever you use with them.
Original flasher unit flashed too fast because I dont have 4 21w bulbs so I bought this
DUAL LOAD LED FLASHER RELAY 3 PIN L.E.D FLASH RATE FIX! | eBay UK
Now it works fine but when you start the engine it flashes too quickly on both hazards and indicators with ignition on or off.
Help?
Thank you
Stu
Have you removed the resistors from the front led indicators? I say resistors because thats what I believe you will have fitted, don't know if it
will make a difference but I did remove mine.
Also have you just pluged the new flasher in or did you have to swap 2 of the wires round.
I have a flasher just like the one you have bought and iirc there were 2 cables that needed swapping.
iirc it was the 'L' and the '+' on the new one that needed swapping.
why have you got 4 side markers?
Originally posted by YQUSTA
Have you removed the resistors from the front led indicators? I say resistors because thats what I believe you will have fitted, don't know if it will make a difference but I did remove mine.
Because I'm doing my IVA and I've got repeaters on the scuttle and the front cycle wings.
only allowed 1 each side
Can you temporerly fit normal bulbs at the front to see it this corrects the problem.
Also is the relay 6v or 12 v?
That would indicate that your LED flasher is either faulty or wired incorrectly. Don't be tempted to fit resistors in parallel to the LEDs - they are simply a fire hazard.
