Just bought
This of one of the forum members to say the westfield instructions are vague would be an understatement.
Probably made to go with westfield harness and indicator switch.
The actual switch in the kit is no problem. I want to replace the original sierra indicator switch with this unit the wire I'm stuck on is the
green/brown one
Black = earth
Green = ignition feed
Green/White = N/S ind
Green/Red = O/S ind
Green/Brown = ?
The harness I'm using is a Vicki Green one,
photo is westfields wiring instructions
[img]
Westfield instructions
[/img]
many thanks in advance
Tony
Been thinking could the Green/Brown be a feed from the indicator relay
[Edited on 7/5/11 by mad-butcher]
hi in my westie book
green/red n/s
green/white o/s
green/brown feed
all of the above go to the what would be your switch now with out this fitted
green ign live
black earth
hope this helps
[Edited on 7/5/11 by JAMSTER]
Many thanks
Tony
